I jut get a new juki du 1181n, can anyone recommend me a servo motor instead of clutch motor that comes with? Also, what is the biggest needle and thread size can it takes? Thanks in advance...
I now get Family Sew motors from Toledo Industrial Sewing Machines. They have a rotary speed control switch on the front and lots of power.
Your Juki is a light duty dual feed machine, with a fixed needle position. It was built to sew cloth garments, not leather. Thread-wise, you'll be pushing it with black #138 bonded nylon. You'll be better off buying the more expensive, but typically softer bonded polyester thread.
Sewing with #138 thread, top and bottom, requires either a #22 or #23 leather point needle. Schmetz are best, if you can get them with an S point favored by most of ussens.
