Have any of you molded an SR40 Ruger holster using an SR40c dummy? The difference is a little over 1/2" in length. How did it work out if you did?
The only obstacle I see would be the rail at the bottom.
It is fairly pronounced and if molding you would need to extend the forming of the rail.
I have made for the sr40c using the full size, by forming the bottom after forming the upper area of the pistol.
If it is not going to be tightly formed you could probably get away with it.
