Hi everyone ,
I am new on this forum , and i'm asking for you're help . I have some problems with my singer 31-15 , the underneath thread is hanging or i don't know how is possible to tangle in this way . I notice that sometie the hooked thread didn't get over the bobin , and that may be the cause of this , but i need some of your suggestion . i have attached a picture of thread. Sorry for my english.
post-45936-0-53615800-1381851410_thumb.j
I had a similar problem with my 1920 Singer 31-15. The top thread would occasionally get picked up too late in the oscillation cycle, preventing it from going around the bobbin. My solution was to advance the timing of the hook, which was done at the far right side of the machine, with the head tilted back on the table. There is an eccentric screw and finger driving the shuttle driver shaft. You have to loosen the nut, adjust the hook forward a bit, lock it down and test for results. These adjustments may also require the needle bar to be repositioned to get the hook above the eye at the right moment and position.
Posted IMHO, by Wiz
I was thinking about this , but i wasn't convinced that may the problem . Thank you for the advice , i will return with results .
I didn't succed to repair it , the thread is picking up too late , but how i can put this in order ? I have adjustet the hook from lef side , the side where is the bobbin , but no results , i dont understand where are you saying to advance the timing from right side ?
Edited by maaryan08
On my 31-15 there is a solid steel pin securing the shuttle driver to the shaft. I had to adjust the hook timing on the right side where the shaft from the top is joined to the shuttle driver shaft, which are visible in your photo.
After advancing the hook, check the position of the point in relation to the ascending needle's eye. The needle must move enough to form a decent loop on the right of the eye. The hook must pass above the eye, somewhere within the cutout scarf area, then grab the loop. Watch this happen with the throat plate off. It may give a clue as to what is or is not happening.
The clearance between the shuttle driver and shuttle makes a difference. Too much slack allows the shuttle and bobbin to self-retard under load. Too little and the top thread gets pinched as it goes around the assembly.
Posted IMHO, by Wiz
Check the lateral clearance between the right side of the needle and the point of the hook. They should be close, but not touch.
Posted IMHO, by Wiz
The hook point and the needle are colse enough , the thread loop is good and the hooking its good , but it's seems to have a delay . After the hook grab the tread and take it to the ending position the thread is not retriving to get over the bobin , and is going back . I don't understand where could be the problem .
I had to fix the same problem on my machine. After advancing the hook and positioning it properly over the eye, I noticed that there was a lot of slack between the shuttle driver and shuttle. This slack allowed the shuttle to back up as the hook grabbed the loop. I had created that extra space to get my replacement shuttle to fit without jamming and overdid it. If your shuttle has too much forward-backward slack, the shuttle will pull back like mine did. The only way I found to correct this was to use a vise-grip and carefully bent the shuttle driver outwards. Only a slight movement is necessary to take up this slack. If your driver is removable, you might try replacing it instead of bending it. Hopefully, your shuttle driver is not steel-pinned on like mine is.
Note: moving the driver in or out changes its lateral relationship to the needle. The driver has a slightly tapered area that helps to push the loop up and to the right, as the needle ascends. Moving the driver outward may cause it to hit the needle and push it to the left. Moving it inward may leave more space than is ideal. So, if you have to bend the driver to reduce slack in the shuttle, you may also have to reposition the driver sideways.
These are really old design machines.
Posted IMHO, by Wiz
The driver is removable . is very difficult beacause the space that will remain betwin neddle and hook if i bend the driver . I don't really have where to buy replecement pars for this machine in my country . I'm thinking if i bend the driver like you said , the thread it will get over easily over the bobbin ?
