Thank you everyone,
I will soon be posting my finished projects up here. I appreciate all the help
  • 4 years later...
Sorry to dredge up the dead, but I am getting to a point where I could try lacing. I got some 3mm flat lace, only to discover that my chisel is 2mm. I wish I knew about waxing the lace first, it might have made it easier. Anyways, I just got a 1 prong 3mm chisel, and would like to know whether horizontal or diagonal slits are better? Would 1/8" spacing from the edge and between the slits still apply?
You really don't want horizontal [parallel] to the edge of the leather. Under any strain they act like the perforations on the edge of a postage stamp
Angled or perpendicular to the edge of the leather is better. You'll find the multi-prong lacing chisels have the prongs at an angle
3mm from the edge. Distance between is commonly the same as the width of the lace. 3mm lace - 3mm spacing, 4mm lace = 4mm spacing --------- but you can do any spacing you want. I once made a copy of a medieval belt pouch; I copied the lacing pattern along the top. It was 3mm [1/8th inch] lace - out the front, across for 4mm, in towards the rear and the next slit was 8mm, out the front, across for 4mm, etcetera
