Members vaalpens Posted November 6, 2013 Author Members Report Posted November 6, 2013 Try angulus 600 or mop and glow cut with water...using an airbrush, you have to remember that your dye isnt going to penetrate very deep into the leather, and any scratch is gonna show releatively quickly... Thanks for the advise! I have seen Angelus 600 and mop and glow being mentioned a few times in the forum and will have to put them on my growing list of things I should try out. Quote
Members vaalpens Posted November 6, 2013 Author Members Report Posted November 6, 2013 While I agree that the dye penetration with the airbrush isn't as good, I have found (in my brief experience) that as long as you follow the dye with neatsfoot oil and finally a good sealer (I use resolene), scratches are not an issue. I have worn one of my original holsters every day at my job which involves getting in and out of a truck constantly all day....no issues with scratches at all even though it is riding next to the seat belt. You definitely have to be careful not to scratch it between the dye and oil stages though. Thanks again for the help. Do you use an oil based dye with the airbrush or is there some special dye that should be used? Also, do you use the airbrush to apply the resolene, or is that done with a dauber or something else. With all this great advise I am receiving, looks like my only limitation is now time and budget. Quote
Members jackd942 Posted November 6, 2013 Members Report Posted November 6, 2013 Thanks again for the help. Do you use an oil based dye with the airbrush or is there some special dye that should be used? Also, do you use the airbrush to apply the resolene, or is that done with a dauber or something else. With all this great advise I am receiving, looks like my only limitation is now time and budget. I use Fiebing's spirit dye. The consistency is just right for the airbrush. As a matter of fact, the caps to my airbrush bottles fit perfectly on the dye bottles...I just screw one onto the dye bottle and spray. Like renegadelizard said, it doesn't penetrate as deep as if you flood it on, but you can make medium brown look brown instead of black. Once thoroughly dry, I apply a couple coats of neatsfoot oil and let that dry thoroughly. This will darken it some, but also makes it more resilient. As a final step, I spray (with the airbrush) a few light coats of acrylic resolene and then let that sit for at least 48 hours. It's also not necessary to go buy a high dollar airbrush...the Harbor Freight one works well from what I understand. As I said, this is my process and it has improved my finishing drastically although I haven't been doing this nearly as long as most of these guys and gals. Experiment some and see what works for you. There are a lot of YouTube videos on these subjects and I'd recommend checking out Eric Adams (Adams Leatherworks) (username Particle on here) channel for a similar process. He does it pretty close to the way I do it. I have also found, for me at least that it is better to spray the resolene...if you apply it with a brush, it may pick up some pigment and mix it around in the finish. Once it is thoroughly sealed, this is no longer a problem. Quote http://DavisLeather.blogspot.com http://Facebook.com/DavisCustomLeather
Members vaalpens Posted November 6, 2013 Author Members Report Posted November 6, 2013 I use Fiebing's spirit dye. The consistency is just right for the airbrush. As a matter of fact, the caps to my airbrush bottles fit perfectly on the dye bottles...I just screw one onto the dye bottle and spray. Like renegadelizard said, it doesn't penetrate as deep as if you flood it on, but you can make medium brown look brown instead of black. Once thoroughly dry, I apply a couple coats of neatsfoot oil and let that dry thoroughly. This will darken it some, but also makes it more resilient. As a final step, I spray (with the airbrush) a few light coats of acrylic resolene and then let that sit for at least 48 hours. It's also not necessary to go buy a high dollar airbrush...the Harbor Freight one works well from what I understand. As I said, this is my process and it has improved my finishing drastically although I haven't been doing this nearly as long as most of these guys and gals. Experiment some and see what works for you. There are a lot of YouTube videos on these subjects and I'd recommend checking out Eric Adams (Adams Leatherworks) (username Particle on here) channel for a similar process. He does it pretty close to the way I do it. I have also found, for me at least that it is better to spray the resolene...if you apply it with a brush, it may pick up some pigment and mix it around in the finish. Once it is thoroughly sealed, this is no longer a problem. Thanks for the how-to steps you have provided. It will help me start the new process with more detail which should help me get going quicker. Interesting that you are using the spirit dye. I have just decide to try out the Fiebing's oil dye since I have heard that the spirit dye leaves the leather harder than the oil dye. You are correct that the medium brown comes out very dark. What I have found is that if I wet form first, then the brown comes out lighter since the dye does not penatrate as well after forming and drying. Quote
Members renegadelizard Posted November 7, 2013 Members Report Posted November 7, 2013 I use the angelus spirit dyes as well, cut 5 to1 with denatured alcohol...i dont think you can really tell any difference in hardness, i cant anyway, but then again, i bake all of my stuff to make it harder, so maybe im not the right person to judge that..after it comes out of the oven and dries in front of a fan for 24 hours, i dip the whole shebang in a bucket of the angulus/water mix, shake it off a bit, and fan dry it for another 24 hours...even on some of the stranger dye jobs ive done (zombie green on ring lizard), ive never had any issues with the dye running...it took me a while to fix my how to steps in an order that worked for me, but once you do, you will rockin..best wishes! Quote Havoc Holsters
Members vaalpens Posted November 8, 2013 Author Members Report Posted November 8, 2013 I use the angelus spirit dyes as well, cut 5 to1 with denatured alcohol...i dont think you can really tell any difference in hardness, i cant anyway, but then again, i bake all of my stuff to make it harder, so maybe im not the right person to judge that..after it comes out of the oven and dries in front of a fan for 24 hours, i dip the whole shebang in a bucket of the angulus/water mix, shake it off a bit, and fan dry it for another 24 hours...even on some of the stranger dye jobs ive done (zombie green on ring lizard), ive never had any issues with the dye running...it took me a while to fix my how to steps in an order that worked for me, but once you do, you will rockin..best wishes! Thanks again for the advise. I have bought some oil dye and will see if it makes any difference. With holsters I like the harder result, but with a sheath I prefer something that feel more natural. I see you indicate you cut the angelus finish by water. What ratio do you cut it? So when you cut it, does it give it a more natural less shiny look? Quote
Members renegadelizard Posted November 9, 2013 Members Report Posted November 9, 2013 Thanks again for the advise. I have bought some oil dye and will see if it makes any difference. With holsters I like the harder result, but with a sheath I prefer something that feel more natural. I see you indicate you cut the angelus finish by water. What ratio do you cut it? So when you cut it, does it give it a more natural less shiny look? I cut it 50/50...less shiny...full strength would look pretty plastic like i think, and the 600 is a satin finish to begin with...the 400 would look like glass... Quote Havoc Holsters
Members vaalpens Posted November 10, 2013 Author Members Report Posted November 10, 2013 I cut it 50/50...less shiny...full strength would look pretty plastic like i think, and the 600 is a satin finish to begin with...the 400 would look like glass... Thanks for sharing the ratio you use. I prefer the satin less shiny look and would start with a 50/50 ratio when I try Angelus 600 for the first time. Quote
