Boriqua Posted November 10, 2013 Report Posted November 10, 2013 I am doing a holster design for someone and I came up with the design attached. Here is my problem. If you look at the dark spots whick is all that will be stamped down they end in fine points. A swoop to a triangular point. I intended to stamp just those dark spaces down but now have trouble figuring out how to do those sharp points at the ends of the dark spots. I may be able to get my background stamp in there but was hoping for other suggestions. Anyone have other (better) ideas on how to pull it off? Thanks!! Alex Quote
Members Wishful Posted November 11, 2013 Members Report Posted November 11, 2013 (edited) If i understand you correctly, I would use a104 or 888 backgrounders . Another alternative is to use a modeling spoon but you will not get a texture. Good luck. Edited November 11, 2013 by Wishful Quote
Boriqua Posted November 13, 2013 Author Report Posted November 13, 2013 If i understand you correctly, I would use a104 or 888 backgrounders . Another alternative is to use a modeling spoon but you will not get a texture. Good luck. Thank you so much!! The 104-2 is perfect. Alex Quote
Members OdinUK Posted November 13, 2013 Members Report Posted November 13, 2013 I'd probably use a triangular bevel in the corners first before the background tools. Quote Lord Of Leather
