I have a back quiver to build for a customer. My ? is : His arrows are 32 inches long, how deep do I need to make the quiver ? Thanks for the help.
22 in. length body quivers .......... it is sufficient size. I use this size for all of your quiver
Martin
http://forarchers.eu/
Thanks Martin
Will you need to silence the arrows for hunting purposes? If that's the case, then you'll need to line the first few inches of the opening of the quiver with some fleece and it'll need to be as close to the fletching on the arrows as possible to maximize the effect of silencing the arrow rattle. I know that there are quite a few pictures of examples to be found online with a quick image search.
Hope that helps
shtoink, I had plan to do this. I do have a goat hide cut out for this . Thanks for the reply.
