How long does this stuff take to cure?
Also, I'm using it to mount beads on pins into the edge of a strap. I want to bore holes in the strap, but the hole is larger than the pin (I've done a test piece, but while I'm waiting for it to set I thought I'd ask). Will the Leather Weld adhere to the pin, or should I use Krazy Glue?
Edited by tashabear
I use leatherweld almost exclusively for gluing leather to wood on my projects. I press the piece under weight for a couple hours to finish "setting". I find that works for me. In your situation, well, I'm not sure. I'd likely give it a try first, and as a backup go with the Crazy Glue.
Holly Moore
Wild Rose Creations
http://www.wrcleather.com
Yeah, the pin pulled right out, so I'm going to go with the Krazy Glue. Thanks, though!
try using the gel control super glue by loctite.
frissenfrassenmussafrussen...
Next time. I have the Krazy Glue in hand; I'd have to go out and find the stuff you're recommending.
walmart and home depot carry it. you can probably find it at lowe's and office depot too. I like it coz it holds well and it's easier to get just the riiiight amount out easily. I'm one of those who always end up squeezing a tube too much and suddenly there's glue everywhere. plus this stuff stays put where ya put it.
The Krazy Glue I have has a brush applicator, so it's really not an issue.
oo! is it the one that's colored purple until it dries and it's clear? I used that one before the gel stuff came out. it was pretty good stuff too. I just hated having to brush, dip, brush, dip, brush, dip... *L*
That's the stuff. It's not that big a deal; there are only six pearls going on the points of this coronet. I'm actually done with it now, but it was so nerve-wracking drilling the holes for the pins that I'm wiped out. There will be pictures later.
