DLC Report post Posted November 21, 2013 I'm assuming that I went to heavy with the spray. Is there way to salvage my piece now? What is the consensus on this product, is it viable if I just use a light coat from now on or is there a better product to get a nice glossy sheen on my work? Quote Share this post Link to post Share on other sites
Chief31794 Report post Posted November 21, 2013 I tried it some time back, didn't like it. There are better alternatives in my opinion. I use Clear Lac mostly. Chief Quote Share this post Link to post Share on other sites
JLSleather Report post Posted November 21, 2013 I've used Saddle-Lac for years. I like the way it looks (and the way it works) but I don't put it on everything - some things just don't do well wit the gloss. And, yes, if I had to guess I'd say you applied it way too heavy. You CAN get that off, with deglazer. Depending on the size of the project (and the tannage, and a few other things) it may be easier to replace the project. About the only time I ever strip the finish off of anything is for a repair, and I don't repair stuff someone else did, so ... Keep in mind that these days there are two different versions of Saddle-Lac. One is much like it always was, the other says right on the jug "new higher gloss blah blah" and they are NOT kidding. I grabbed a couple a whle back, not realizing i was getting one of each. Big difference. Quote Share this post Link to post Share on other sites
DLC Report post Posted November 22, 2013 I'm using an aerosol spray, it sounds like you're using a liquid. But yeah, I've just redone this project from the ground up. I'm only going to use this finish on pieces that won't be subject to high stress. Quote Share this post Link to post Share on other sites
