Dangerous Beans Posted December 5, 2013 Author Report Posted December 5, 2013 (edited) Hi Nigel, Thanks for sharing this great tutorial! I'm interested in starting on my own project as well, but I need to know how many bags I can make from a side. I'm making a 15"(W) by 11"(H) by 5"(D) bag, I estimate that I'll need about 7.15 sq ft. of leather. The following piece of hide looks GOOD, about 25 sq ft. http://www.ebay.com/itm/Old-World-LATIGO-COWHIDE-LEATHER-24-27-Sq-Ft-6-oz-1-Quality-British-Tan-AE1/290943363410?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D18474%26meid%3D3154465751735074165%26pid%3D100033%26prg%3D8385%26rk%3D1%26rkt%3D4%26sd%3D290943363410%26 If I manage to find someone skilled or maybe even you!, can I assume I can make 3 bags out of this 25 sq ft piece of hide? I'm estimating as this piece is costly and I want to know how many bags I can make before I commit... Thanks! Square footage will not always guarantee you will get as much from a hide as you expect. Trimming off one side to get a straight edge will create wastage. Scars and marks that need to be worked around also create wastage. You have estimated 7ft per bag, 21feet in total from a 25 foot piece of leather. The leather would have to be very high quality to achieve that. A piece marked as rustic I imagine will have scars. I think it's ambitious to expect 3 bags from this. You will need 3 shoulder straps and 3 gussets that's 18 inches from the hide straight away. To be as economical as possible, cut a pattern out and mark up the hide before cutting anything out. Making your gussets out of several pieces and possibly even the flap will give you greater scope. I think if you aim for two and if you get a third through clever cutting you are on a winner, or adjust the size of the third to suit what's left and make a smaller one to use it up. But don't stop searching... You may find someone skilled yet! Nige Edited December 5, 2013 by Dangerous Beans Quote The secret to creativity is knowing how to hide your sources. www.armitageleather.com
Members hornm Posted December 5, 2013 Members Report Posted December 5, 2013 Nigel, Thanks so much for puttting together these videos as well as offering the patterns. Your time and effort in assisting the rest of us is greatly appreciated. Horn Quote Michael "If the women don't find you handsome, they should at least find you handy" Red Green
Members Firdaus Hilmy Posted December 5, 2013 Members Report Posted December 5, 2013 Multiple gussets, a bit much to explain here, I think another video would help, but if your in a hurry, drop me an email and I'll explain. Nige I want to know too! will wait for your another videos and thanks for posting! Quote
Members Feraud Posted December 5, 2013 Members Report Posted December 5, 2013 I too appreciate the time and effort in making the videos. They are a valuable resource for the leather-working community! Thanks. Quote
MadMorbius Posted December 6, 2013 Report Posted December 6, 2013 Nigel, thanks for sharing. Could I ask what thread (size and make) you're using for the 7 to 1 stiching? It looks like braided cord, tough to find here in Canada. Quote
MadMorbius Posted December 6, 2013 Report Posted December 6, 2013 Can you talk about the process of sewing a double gusset bag? I am interested in creating a two compartment messenger bag and I am sort of at a loss on how to approach the double gusset. I'm sure Nigel can explain it better, but you do it the exact same way...instead of cutting out a single front and a single back piece plus pockets, cut two front pieces, and twice the gussets. Put the second of the "front" pieces in the middle between the gussets with the good side facing the front of the bag. Glue the front and rear gussets to the center piece, then lay out your stitches with the pricking iron...sew the center gusset first, then carry on as per the video. For the strap I use a shield and tab that bridges the gusset and sews onto the center of each. Quote
Members kjmilligan Posted December 6, 2013 Members Report Posted December 6, 2013 I'm sure Nigel can explain it better, but you do it the exact same way...instead of cutting out a single front and a single back piece plus pockets, cut two front pieces, and twice the gussets. Put the second of the "front" pieces in the middle between the gussets with the good side facing the front of the bag. Glue the front and rear gussets to the center piece, then lay out your stitches with the pricking iron...sew the center gusset first, then carry on as per the video. For the strap I use a shield and tab that bridges the gusset and sews onto the center of each. Thanks for the advice! That is very helpful. In my conceptualization of the process, I've come across another problem though... Instead of a single center piece, I want to form it from two pieces of probably 4oz veg tan and have it as a central laptop compartment (pictured here). Additionally, I want to line that laptop compartment with wool felt, unfortunately adding to the thickness. This would mean that I will be sewing 2 gussets, 2 middle pieces and 2 layers of wool together, which I am picturing to be VERY thick. I am weary about skiving from the leather center piece or the gussets, because I want the bag to last. Any thoughts on this process? Thanks. Quote
MadMorbius Posted December 6, 2013 Report Posted December 6, 2013 In the attached he's using 4-5oz leather for the inside compartment and 7-8oz (probably) for the rest of the bag. So the two layers aren't that much bigger together than a single divider would be. If you're going to do something like this, note the extra inches required to sandwich something between the layers...Even more space if you use wool. Lining the compartment with wool adds bulk and complexity that may not be required given the laptop section is already protected by the other compartments. But if I were to do it, I'd glue/stitch the wool down to the two outer flaps, leaving 3/8" from the edge of the divider pieces (inset your wool 3/8" from the gusset edges) to avoid the extra thickness at the gusset seam. OR, I'd run an accordian gusset on the inside (a second gusseted compartment inside the main bag). Quote
Members Ski Posted December 7, 2013 Members Report Posted December 7, 2013 To me it looks like braided polyester tigre thread but Nigel can confirm better than me. if it is, Ive seen people import it into the US via Abbey England Quote Warm regards, Mark Skiba
MadMorbius Posted December 8, 2013 Report Posted December 8, 2013 Thanks Ski, I think you're right about the type. Would love to confirm the weight however Quote
