harry phillips
Softening 3Oz. Veg. Tanned Leather
I've made a tote from 3oz. Veg. Tanned leather. I finished it with antiquing gel. It has a tooled/dyed design . I've tried neetsfoot oil in the past and it bleed through to the front and didn't look well. Tried a leather conditioner,lexol, same results. Thanks Harry you can see in the photo on the right side some discoloration caused by conditioner used on inside.
post-40809-0-06493200-1389104563_thumb.j
I think you are attempting to use the wrong product in the wrong way :)
When using the oil it should be applied to the outside of the item.
You will need to apply a "finish" product that seals as well as finishing the leather. You may have some problems with your selection of color product
either way. Some testing on a piece of scrap would be well advised.
ferg
agree with ferg....very light coat of oil on grain side....and i only oil to bring out the reds in leather for sherdan finish....otherwise, oil really is not needed- depends on how well you control the moisture content while tooling- as moisture evaporates it leaches out some of the fat liquors n oils used in tanning
Edited by Jwalker
