Members jtron5 Posted January 12, 2014 Members Report Posted January 12, 2014 (edited) Hey all, having serious issues with saddle lac. I know it is not the preferred finish for many, but I need a super high gloss here. I've been using the light multiple coat approach, but all of a sudden I'm seeing lots of grey spots (as in the picture). Any advice would be be awesome! Edited January 12, 2014 by jtron5 Quote
Contributing Member JLSleather Posted January 12, 2014 Contributing Member Report Posted January 12, 2014 Tough to be sure from your picture, but it looks like your nozzle may be partially clogged. Hold the can upside down and spray for a couple of seconds. This will clear any liquid from the nozzle (you'll see it stop). Store it like that. When you get ready to use it, spray just a second or two over a trash can or board (like, anything NOT your project). Maybe that's a primer? Spray what you need to spray (light coats is correct). When done, again, spray upside down until cleared. The stuff hardens, idea is to have it harden somewhere NOT in the nozzle. And most foks spray way too much of it. A 13 oz can (I think is what they are) should last about .. oh --- 100 years, unless you're spraying multiple projects every day. Note there is now another 'version' of Saddle-Lac, with more gloss than before. I bought the "extra" glossy by mistake (didn't look as I grabbed), and I don't care for it. Other stuff I've used for years. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members jtron5 Posted January 12, 2014 Author Members Report Posted January 12, 2014 Thanks for the advice. I'll check the nozzle. Quote
Members Toolingaround Posted January 21, 2014 Members Report Posted January 21, 2014 Hi There I use Saddle Lac all the time. It is great for a very water resistant finish but is prone to cracking as most lacquers are so I put in on very thin by spraying on a scrap of shearling and quickly rubbing it on. Sometimes I do two thin coats but only if I must. If you go to the saddle makers forum and research how they apply neat lac etc. you will get more info. I use the same technique. Hope that helps. Cheers, Toolingaround Quote
