Hello again, I've seen several holsters that use a type of plastic snap instead of a brass or nickel snap. It appears that the rest of the snap is metal, however the actual back piece is either made of plastic or has a plastic sleeve. This type is used where the metal from the snap touches any metal part of the weapon. Can any one tell me where to find this?
Sincerely, Daniel
Thanks for the info, I"ll check it out, Daniel
  • 2 weeks later...
L/Bum, I do believe I found what I'm looking for. Thank you so much.
Sincerely, Daniel.
