mlapaglia Posted January 21, 2014 Report Posted January 21, 2014 Here is the reference I was using http://www.bowstock....king_irons.html I saw that too. I tried my best not to say you were wrong but the information was flawed. if I failed you have my apology. Tooth pitch is defined as the distance between teeth(This applies to saws). This can also can not be correct since a single prong 2,3,4mm pitch tool can be purchased. Therefore my first post is totally wrong also. I got that information here. Quote The key to immortality is first living a life worth remembering. Bruce Lee
mlapaglia Posted January 21, 2014 Report Posted January 21, 2014 (edited) Possible solution. Forget pitch get a Dixon pricking iron. They sell them #/inch so a #6 is 6 per inch. no messing with pitch. If you dont like the size of the mark the Dixon leaves you can contact them and ask them to make you a 6/inch pricking iron but with a width/thickness similar to that of a 10 or 12 they will probably do it for you . As they mill the tools themselves , special requests are not a problem. There are several Dixion irons on E-bay if you want to pay less than new. FYI since Dixion does not talk about pitch and a 6 is 6 SPI its probably why most of us think that the number we thought was pitch was the size per inch. Edited January 21, 2014 by mlapaglia Quote The key to immortality is first living a life worth remembering. Bruce Lee
Members TXAG Posted January 21, 2014 Author Members Report Posted January 21, 2014 I am glad you all were able to see how I was confused by this. I consider myself to be fairly intelligent, but I wasn't able to figure their pitch sizes out. I'd love to get a Dixon, however, there is a very large price differential between theirs and the LeathercraftTools one, even used. I'll keep looking though. Thanks everyone for your efforts in trying to help me figure this out... Also, is 6 tpi generally a good stitch width for wallets and small pouches? I know it probably depends on the leather thickness..the wallets I've made before were 3 layers of about 6-7oz. I'll also be making a roper wallet soon...wondering what the best spacing might be for it too. Quote
mlapaglia Posted January 22, 2014 Report Posted January 22, 2014 (edited) 6 tpi is fine for what you are doing. I use it for anywhere from 1 piece of 5 oz to 3 pieces of 9 oz. Check Ebay. I have had good luck with the company in that link,. 28 dollars is good price and better quality than a 5 dollar iron from your link. Per electrathon's post above a 4mm is for all practical purposes a 6 tpi. I really doubt the ones you are looking at will last at the price they quote. They say "LeatherCraftTools.com's Diamond Hole Punch PRO has the fully-quenched body," but do not say what the metal is. Probably iron not steel. probably bend easy. You have to store it coated in machine oil so it is an iron type metal of cheap steel. quenching is not enough to make iron useful but could make it brittle if done wrong . (God I hope I remember my high school metals shop correctly ) If you have to go cheap get the Tandy Pro line ones. At least we know they are pretty good and you can test them at the store and see which one is the one you want. Or call the store and ask them which is 6 tpi. Edited January 22, 2014 by mlapaglia Quote The key to immortality is first living a life worth remembering. Bruce Lee
Members Nuttish Posted January 24, 2014 Members Report Posted January 24, 2014 (edited) Those aren't pricking irons. They're punches. They also look sort of shitty. A pricking iron barely marks the surface; you then open your hole with a diamond saddler's or harnessmaker's awl. Actual pricking irons are nearly unknown to American leatherwork anymore so they're difficult to find over here. They're the standard for European work. The contemporary American equivalent would be an overstitching wheel. However, you can easily find reasonably priced vintage Osborne and Gomph pricking wheels, which would lay tiny diagonal marks without piercing the grain like a pricking iron. Look at Bruce Johnson's site. He has a lot of very nice old tools for good prices. Osborne is the only US manufacturer of actual pricking irons. https://www.osbornel...ils.php?pid=424 . Otherwise you're spending quite a lot to get a European tool. 6 tpi may be very wide for a wallet depending on the thread you use. What style of work do you intended to do? If you like, I can post some pics comparing stitch lengths of 6-12 tpi with various threads (including Tiger - it really doesn't look like traditional linen thread at all) and showing what some of these tools look like next Wednesday when I get back from a trip. Update: Ok 3 layers of 6/7. So if you're making Costanzas I would recommend sticking with 6 tpi. Edited January 24, 2014 by Nuttish Quote
Members TXAG Posted January 24, 2014 Author Members Report Posted January 24, 2014 (edited) If you're trying to imply that I make huge, uncomfortable wallets by your use of the term "costanzas", you would be wrong. Also, I already have an over stitch wheel. I dont' like it because it's a huge pain in the ass to use. That's why I want a PRICKING IRON. Edited January 24, 2014 by TXAG Quote
Members Nuttish Posted January 25, 2014 Members Report Posted January 25, 2014 Ok then. If you want a new pricking iron, you've got Osborne, Vergez Blanchard, Dixon's, maybe Craft Sha, and poor quality Chinese or Korean stuff. If you want a chisel, you've got the options everyone else told you about. Pricking irons and chisels are different tools. Have fun. Quote
