Members Mack51 Posted February 26, 2014 Members Report Posted February 26, 2014 I have a Singer 168w 101, a post machine. I am teaching myself to sew and right now I have a clutch motor and want to change to a servo. There seems to be few to choose from and having looked on e bay also. I have a budget of 200, I am retired. Need help in picking out one, any ideas. Currently I am leaning on one on e bay from S.E.W. for 139.00 and it has the S.E.W. label on the motor. Looks the same as a Reliable. John Quote
Members pcox Posted February 26, 2014 Members Report Posted February 26, 2014 Call Toledo Ind. Sewing Machine 1-866-362-7397 ask for Bob. I have bought several servo motors from him. nothing but the best. Quote
Moderator Wizcrafts Posted February 26, 2014 Moderator Report Posted February 26, 2014 (edited) I agree with PcCox. I have bought all of my servo motors from Toledo Industrial Sewing Machines. Right now, the cream of the crop is the Family Sew FS-550 that he sells already equipped with a 50mm (2") pulley. You'll need to do some math to get the correct new v-belt length. See if your current belt has a length designation (e.g.: M44, 42", 3L40, etc). Then measure the diameter of the current motor pulley (assuming that the motor tension adjuster is somewhere near the middle of the bolt). Divide the existing pulley diameter by 2" and whatever the result, that is how much shorter the new belt needs to be. Example: Your machine has a 4" pulley on the clutch motor and a 44 inch v-belt (or leather belt). The motor you are buying has a 2 inch pulley and sits about the same distance under the table, for the motor output shaft. Divide 4" by 2" = 2. The new v-belt (type 3L) would be 44 - 2 = 42 inches. Variables are the vertical position of the motor shaft and the current position of the bracket that positions the motor and tensions the belt. If the adjuster is already at the bottom, you'll possibly need an even shorter belt and vice-verse.. This also assumes three bolts holding the motor on. Edited February 26, 2014 by Wizcrafts Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
