I have searched and found many references to resolene and not letting it freeze. Says so right on the bottle, even. So my question is if it has frozen, is there any help for the bottle, or is it just gone. I am assuming it was frozen in transit as it is curdled and can not be shaken, nor stirred back to homoginized. (sp?). Or does it even affect it when you use it curdled?
Once again, thanks so much.
If your not going to send it back. I would get some out into a resealable bowl like tupperware and add some water and see what happens. I have some that had got pretty chunky in the bottle and i added some water and it's fine.
Thank you kind sir. That is what I shall try.
