jack2332
How To Install Hasp On Briefcase Lock With Revits?
does anyone have any idea with what this hasp is installed? Both ends inside and out seem to have a revit or pin head of some sort.
how do they do that to get it to be the same on both ends?
a tube or split revit would show the split on the other end.
maybe a pin flattened but that would bend and scratch up the front end
i dont think its a force fit revit as none are that small
any ideas how to install a hasp like this with available tools and a clean non scratched up way?
post-37360-0-11354800-1396491484_thumb.jpost-37360-0-18782800-1396491489_thumb.j
It looks like just a basic rivet. Think of a piece of wire with both ends smashed. Or a nail with the sharp end smashed.
You can easily use a nail. Snip it where it sticks through and a rivet set can be made from a small rod with s divot drilled into the end.
If you dont mind spending a couple of bucks, a nail set would be better. Hardened steel, and meant for hard use.
Chuck
