treborterb
Reposition Balance Wheel?
Is it possible to reposition the balance wheel from the right side to the front of the machine on a Singer 29-4?
The answer is no unless you change the cam on the main top shaft. The 29-1 thru 29-5 did not have the helical gear on the cam. it was added on K models so that a hub, shaft and gear assembly would go on. This allow you to move the balance wheel and collar from the end to the front of the machine. All you have on your 29-4 is a cover plate.
