Members sinpac Posted June 6, 2014 Members Report Posted June 6, 2014 (edited) Henry G. Gomph worked under his own name from 1865 until 1872 and then with the & Co mark until 1923.My question is the brass ferrule has a hair line crack in it. Do I have it repaired or leave it because it might be a rare tool. Thanks, Chris Edited June 6, 2014 by sinpac Quote
Moderator bruce johnson Posted June 6, 2014 Moderator Report Posted June 6, 2014 Nice tool and I'd replace the ferrule for sure, but that's me. There is a check in the wood and I'd go so far as to rehandle it if I had one with the right receiver for the shank. Quote
Members sinpac Posted June 6, 2014 Author Members Report Posted June 6, 2014 Thank Bruce. Where would I go to replace the ferrule? It funny I never seen the split until I look at this picture. I was thinking some thinned down Titebond 2 in a hypodermic then apply a hose clamp until dry. Your thoughts? Chris Quote
Moderator bruce johnson Posted June 6, 2014 Moderator Report Posted June 6, 2014 To replace the ferrule you have to take the bit off, slide a fresh one on, the replace the bit. I have some and do it pretty frequently if you'd want to send it here. Quote
