Members veedub3 Posted June 28, 2014 Members Report Posted June 28, 2014 (edited) Would you mind posting photos of what you mean? Also, is the process to paint the edges (Edgekote?) then heat seal? Thanks. No I am referring to Edge Paint not Edge Coat. I use a product from Japan that I am told is similar to Fenice Edge Paint. You paint it on then heat seal it. Here is a video that shows the process of applying the edge paint. I don't have the machine she is using I just use a fine tip brush to apply. https://www.youtube.com/watch?v=k3-XM-jPOmk Karina Edited June 28, 2014 by veedub3 Quote "The only man who makes no mistake, is the man who does nothing." Theodore Roosevelt
Members veedub3 Posted June 28, 2014 Members Report Posted June 28, 2014 Im interested as well. There is also another tool in this thread that I found searching this subject. One guy posted pictures and his results looked really nice but the thread seemed to just end without any further info. here it is. http://leatherworker.net/forum/index.php?showtopic=38750&page=6 http://www.woodcraft.com/product/2001813/2546/tool-kit-10-in-1.aspx#ProdInformationTab this is the tool and comes with multiple attachments. also on ebay I saw these which look interesting.. curious if anyone has used them. Look like the wooden dremel burnishers with different size grooves. http://www.ebay.com/itm/like/331208933594?lpid=82 That last link you posted I was thinking about picking that set up some time ago but I ended up getting a wood slicker from leatherburnishers and just didn't bother, although I am sure if chucked in a Dremel it would work the same as the wood burnisher I have. I did a test today on a scrap piece of vegtan. (I want to say upfront that I had no idea what the heck I was doing but here is the process) I first use liquid glycerin and a wood slicker on the edge to lay down the fibers. Then I went over it with beeswax and use the hot tool to melt in the beeswax. I am thinking I had the temp too high because it appears to have darkened the leather quite a bit. Maybe if I would have applied a finish on top it would have turned out better, but......... Here are some pics: 1. The first pic is an edge done the Bob Parks way. 2. The second pic is black edge paint that has been hot glazed. (can't really tell in the photo but up close it looks just like a plastic coating of some sort. (Not a fan of that look) 3. The third pic is the edge I did with beeswax and the hot tool. I am sure with more testing I can get this method to work, and as I stated before I had no idea how this should have been done, but for now I will just stick with Parks method. Karina Quote "The only man who makes no mistake, is the man who does nothing." Theodore Roosevelt
Members mrtreat32 Posted July 1, 2014 Members Report Posted July 1, 2014 That last link you posted I was thinking about picking that set up some time ago but I ended up getting a wood slicker from leatherburnishers and just didn't bother, although I am sure if chucked in a Dremel it would work the same as the wood burnisher I have. I did a test today on a scrap piece of vegtan. (I want to say upfront that I had no idea what the heck I was doing but here is the process) I first use liquid glycerin and a wood slicker on the edge to lay down the fibers. Then I went over it with beeswax and use the hot tool to melt in the beeswax. I am thinking I had the temp too high because it appears to have darkened the leather quite a bit. Maybe if I would have applied a finish on top it would have turned out better, but......... Here are some pics: 1. The first pic is an edge done the Bob Parks way. 2. The second pic is black edge paint that has been hot glazed. (can't really tell in the photo but up close it looks just like a plastic coating of some sort. (Not a fan of that look) 3. The third pic is the edge I did with beeswax and the hot tool. I am sure with more testing I can get this method to work, and as I stated before I had no idea how this should have been done, but for now I will just stick with Parks method. 1.png 2.png 3.jpg Karina All those edges look pretty good. Although that is on veg tan which burnishes nicely. You have used it on other types of leather as well? ( the soldering iron) I have a wood dremel burnisher as well but I was under the impression the last one I posted from ebay was meant to be connected to a soldering iron. That way you can heat treat the edges of the piece like the other tools posted. Not sure the spinning metal would have much effect although I could be wrong. Quote
Members veedub3 Posted July 1, 2014 Members Report Posted July 1, 2014 All those edges look pretty good. Although that is on veg tan which burnishes nicely. You have used it on other types of leather as well? ( the soldering iron) I have a wood dremel burnisher as well but I was under the impression the last one I posted from ebay was meant to be connected to a soldering iron. That way you can heat treat the edges of the piece like the other tools posted. Not sure the spinning metal would have much effect although I could be wrong. Yes the last picture you posted is designed to be connected to a soldering iron. I was simply saying that i choose not to get it as the wood burnisher I already had works well so I just didn't bother. In my photos, the first one done with a wood burnisher connected to a dremel. The 2nd photo was to show JanC that I was referring to Edge Paint, not Edge Coat - done with the heated brass tip connected to a soldering iron, and the 3rd photo was done with the heated brass tip connected to a soldiering iron on regular vegtan. (The last photo IMO did not turn out too well) I have only used it on thin leathers that are too soft to burnish normally. (Bag leather using the edge paint) I do have some Chromexcel and Oil tanned leather that I can try it on, as soon as I get a minute I will try to get some pics of those. Karina Quote "The only man who makes no mistake, is the man who does nothing." Theodore Roosevelt
Trox Posted July 9, 2014 Report Posted July 9, 2014 I have one of them. The (rod) part that goes up in the soldering Iron has a diameter of 5 mm. Tor Quote Tor Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
Members Fat Dog Leather Posted July 18, 2014 Members Report Posted July 18, 2014 Veedub3, I am looking for a edge finish for softer leathers that are chrome tanned. I have tried using the Fenice edge paint and then the hot iron on top. The result is okay but not the professional look I am after to actually meld two pieces into a smooth coated edge. Not sure what I am doing wrong. Any suggestions? Thanks Quote www.fatdogtradingco.com fatdogtradingco@yahoo.com
