Michelle Mall
Please Help! Questions About Consew 206 Rb-1
I just purchased a Consew 206 RB-1 and I'm trying to put a new belt on it. I can't find any information on installing a belt for it and the manual I have for it says nothing about the belt. I found info on the RB-5 that says the deflection on the belt should be 15-20mm. Is that the same for the RB-1?
And where do you adjust it to get it to this deflection?
Which belt are you replacing ? The shaft belt or to the motor?
