jeremyqmartin
Resolene On Thin, Soft Pigskin?
I was looking up some info on making pockets with pigskin and found someone mentioning that they put "acrylic" finish to "seal" the pigskin.
The skin I have is the soft tan kind from Tandy. I'm using it to line my briefcase and was now going to make some basic pockets on a divider piece.
Would one really put resolene on this? I tried it on a small piece and got a blotchy look (see the small piece right next to the foam brush)
post-40364-0-42023800-1405924071_thumb.j
It would be tricky to apply to thin leather without getting blotchy areas.
You may try a light coat of Obenauf's to seal it instead. Its a dense gel and can be applied lightly so it doesn't discolor the leather but seals it.
http://www.amazon.com/Obenaufs-Heavy-Duty-4oz-Preserves/dp/B003SKCARK/ref=sr_1_1?ie=UTF8&qid=1406146600&sr=8-1&keywords=Obenauf%27s+LP
I use this stuff on almost everything. I apply Neatsfoot oil first and then put a layer of this over it.
In your case though, you can apply a very thin coat of it by hand.
