I don't know the exact thickness of the straps. I ordered a double shoulder in 8/9oz and split it down to what looked about right, maybe a little over an 1/8". I have a piece of 5/6oz left over from another project that seems just a little light, so 6/7 would probably be about right.
For the sole I used 1/4" Soletech diamond crepe. http://www.ebay.com/itm/SoleTech-Diamond-50-55-Durometer-Crepe-Soling-Sheet-1-4-12-iron-6mm-/221258577334?pt=LH_DefaultDomain_0&var=&hash=item338409f5b6
I found them to be rather hard and uncomfortable, although I guess it should actually be softer than a leather sole.
I have ordred a couple sheets of 1/8" 30/35 durometer puff eva from here to try as a middle layer along with some of the mini check sheet for outsole to try. The 30/35 durometer is actually a lot softer than I was expecting, and I have some concerns about how it's going to hold up to compression. Perhaps it will actually work out well and conform to the foot.
Old, maybe. I'm glad you contributed. I'd have like to see more in the thread. I am glad you opened it back up.
Kevin Orr
hackaday - thanks for the quick reply. My thoughts along with looking at sandals/flip flops on etsy would be using the crepe you linked to with some B grade horween for the top of the sandal ( not up with terminology yet), the straps could be just about anything that will hold up. Is there a chance we are over thinking this? BTW - your FF's turned out great imo. why stitch thru the crepe? would the stitching add strength or decoration? I would stitch thru the leather with a contrasting color or design, then cover it with the crepe. The reason I researched making these is bc my wife/daughter saw some on etsy and wanted me to make them, they also had their own designs...
The 30/35 durometer is handled by the same seller on ebay. I started following him and went to his store. He has many items that may be useful.
Tony
Edited by retiredff
I found by searching on ebay finds some rubber sheets, search: shoe repair sheets
  • 1 month later...
Finished up another pair. The original strap design/width didn't really feel very secure with how big the sandals are. They were pretty hard and uncomfortable too with the 50-55 durometer crepe sole. The new ones have a layer of 30-35 durometer foam midsole (2 layers under the back to give a little bit of rise to the arch) with an 80 or 90 durometer outsole. The soft foam was much softer than I thought it would be and I was concerned it would compress too much, but hopefully it will just conform to the foot nicely.
post-40329-0-82929600-1434070349_thumb.j
post-40329-0-85731500-1434070350_thumb.j
post-40329-0-91899600-1434070351_thumb.j
They look really good, the stitching especially. Keep us posted on how you like them.
  • 3 weeks later...
Thank you guys for the kind words! I appreciate it. I was pretty happy with how they turned out for being my first real stitching job. Next time I think I will not stitch through the suede. It's not bad, but the thread does rub a little. Maybe I just need to toughen up.
