DavidL
Treadle Industrial Singer.
I have a few questions Id like to get some opinions on.
1. Treadles. Can they be added to a non functioning electric singer (faulty wiring) and are all treadles compatible?
2. on the 45k and 111w can an edge guide be added?
3. Which of the 2 models work best as an overall machine also which will have the least problems?
Generally yes - you can treadle almost every sewing machine but it depends on the machine and treadle combination. I think you will have a hard time to treadle a 45K with a treadle of Singer 201 domestic machine. Heavy machines need a heavy treadle.
On flat beds yes on cylinder beds it depends on if the arm has an attachment plate or not. But on 111w cylinder beds you alternatively can add a flip down edge guide.
Depends on how thick you want to sew - if not more than 3/8 I´d say the 111w is better if it has a walking foot system. And for the 111w you find a wide range or accessories whereas accessories for the 45K are harder to find. Both do not have problems if they are well serviced and adjusted and you don´t overcharge them.
A servo motor + speed reducer is for sure the better idea - much more torque than just a treadle!!!
Sure, you just need some bolts and tools + 1 or 2 new V-belts. Depends on where you install the reducer + motor.
I prefer treadles to servos as the speed change is almost instant.
The 45k was built as a treadle but the fame, footplate and band wheel were about 5 times the weight of even a standard industrial treadle.
45k edge guide is not a problem. There is one for the GA5 and another for the 441 but with either I think the holes need to be redrilled. and getting screws could be an issue although you could drill and retap.
The 45k89 is a walking foot but there is a roller foot available for the 45k21 and 45k25. I know this for a fact as I have them in stock on ebay Australia. In the not too distant future I will have new standard feet available as well as needle plates. ATM I have about 40 new-old-stock feed dogs.
http://www.ebay.com.au/itm/Leather-Roller-Foot-For-Singer-45k-45k25-45k21-GA5-GA5-1-Cowbow-CB2500-/221448164280?pt=AU_Sewing&hash=item338f56d3b8
A flatbed attachment is easy to make.
