KY23 Report post Posted August 14, 2014 Started my first Sheridan style belt. I can tell I'm improving. This first attempt looks kind of sloppy. I used non-sheridan style tools. Still happy with the outcome. Waiting on my Wyo Sheen to antique. I started a new section using sheridan style tools and it does look better. More detailed. I am also playing with a craftool pedal lifter. I like the effect but still learning how to use it. Not much documentation on how to use it correctly that I can find. Quote Share this post Link to post Share on other sites
Bob Blea Report post Posted August 14, 2014 You're off to a good start. It does look like your leather may be too wet when you are tooling it. Also, I see in a few places where you didn't stamp your veiner on the leaves the same way on the same leaf. For the petal lifter, looking at the flower in the second picture I think your using it correctly. I tap mine into the curves I want to lift and then tilt it back on it's heel slightly as I pull it out. This causes the flower petal to rise up more and give more relief. Hope this helps, Bob Quote Share this post Link to post Share on other sites
KY23 Report post Posted August 14, 2014 Thank you Bob. I wasn't properly casing my leather. I've just started more practice on a properly cased piece of leather that is much more dry and I can really tell the difference. Easier to tool and much better results. Quote Share this post Link to post Share on other sites
KY23 Report post Posted August 15, 2014 Tried again by making a dog collar for my Giant Schnauzer Sam. Used properly cased leather this time. Much better I think. Still practicing the details. Quote Share this post Link to post Share on other sites
