Well I've spoken to a few people who dye jackets, I'm afraid it looks like I'm on my own.
1) It is prohibitively expensive and 2) there is a risk I'm not happy with it anyway.
So I might have to do it on my own!
This is where we buy our leather jackets for work... They repair and refurbish them as well. If you are feeling funny about doing it yourself, give them a call, I bet they would do it for you.
http://www.taylorsleatherwear.com/cleaningleather.htm
I would love to but they are in the States I'm in the UK
This is the sort of dark brown I'd like to go to, not sure if it's possible. I'm worried the seams also won't be dyed.
Edited by koolio
  • 4 months later...
I am not sure if it is WAY too late for this, but I have successfully overdyed a medium brown jacket a darker brown, in a manner to make it look worn. I used dark brown Fiebings dye and Kiwi black dye with the spongetop applicator. You can see what I did here, and maybe adapt it to what you need? The Fiebings penetrates deeper than the Kiwi dye, but I am reading mixed messages into your request. If you want the aged look, you cannot really use a dye that will penetrate or you will have a difficult time getting those light spots that mimic wear. I believe the Belstaff leather is wax rubbed to get the antique finish, but you can sort of mimic the look by overdyeing.
Here is the original monotone chocolate brown color:
After the overdying process with brown Fiebings and Kiwi black dye:
I used less black where the jacket would normally wear to give it the look that color rubbed off there. Also scuffed up the snap and hit it with black to dull the shine back.
It's not too late at all, thanks so much for writing in. I think you must be psychic because I only recently started thinking about doing this again! Your work looks excellent btw.
I had some really poor results with Fiebings oil dye, I was using a black and have found it's always left a sort of purplish hue on the top, I don't think I want to use it again.
They occasionally are depending on the model but the one's I've actually shown and my jacket are actually sealed in a satin.
Well I'd want a penetrating dye get the aged look and then satin seal it for permanency. I'd not want a wax finish.
I like what you've done with yours except for I'd be after a very dark brown/black look or black aged in parts/seams to a very dark brown. Just like the last photo I showed really (and in the same vein as you have done). I have the added problem of starting with a very light brown.
Still have no idea where to start or how to go about it really, have had so many suggestions from leather redying companies, this forum etc. etc. and still pretty much a complete novice.
Edited by koolio
The main problem about the Fiebing dying was that it left a metallic greenish color, but I put my jackets through the washing machine to help age them and it took a lot of the residual unwanted color off.
Then the black dye covered it pretty well. The thing about the black dye is that I wipe it on, wait and wipe it off before it dries much so that it just leaves a darker area, but most of the brown shows through. So light brown + black = darker brown. I expect if you either did that a few times or left the dye on longer you can darken it nicely.
The difference is that I used an eBay jacket that I got fairly cheaply and if I ruined it, I ruined it. Who cares? I also did the black Kiwi dye on an $800 Horsehide jacket from Lost Worlds, so I am foolish that way. You can see the difference in the interior panels from the original color:
In any event, you will want to remove the protective finish if it is on the jacket so the dye penetrates easily. You can actually dampen the jacket with a spray bottle and dye it damp for more consistent results.
I usually finish the distressing by treating the jacket with Pecard Leather Dressing which will add most of the oils back to the leather that I washed out in the washing machine. It is a little like vaseline, but you wipe it on lightly, wait a while and then wipe it off. It looks shiny for a brief while, then that goes away.
I don't want to risk a washing machine I'm afraid!
Are you sealing the dye in with something? My jacket's going to be used in the rain etc. and I don't want to wax it.
I do not blame you. It can be scary and fairly risky if not done properly.
I have not sealed the dye in any of my jackets after dying them with either Fiebings or Kiwi. I wear them in all kinds of conditions too. I just hit them with a few treatments of Pecard Leather dressing, which is more of a protectant and conditioner than a sealer.
The only way the dye has been altered after an overdye is by using wither isopropyl alcohol or acetone. Typically the isopropyl is enough.
But I still feel that a rinse of sorts is necessary after a dye job. The first time you put your arm around your wife and some excess dye rubs off onto her brand new white designer jacket, you will wish you did. Maybe it can just be wiped with a damp cloth, I have no idea. I am kind of an advocate for the "all or nothing" method. LOL.
