horseplay
Tool Belt Hardware
I am looking for a metal tape measure clip found on most tool belts. Several of the commercial ones I see have "Tape Holder" stamped into the metal.
You have to custom order those clips. You just aren't going to find them in stock anywhere...much less with the tape measure etching on them. Several companies can handle that for you since its an easy 4 bends and 2 holes piece of metal. I listed a couple of them below.
http://www.peninsulaspring.com/flat-springs
http://www.keatsmfg.com/custom-brackets-custom-clips.html
But...
If you want to stay away from custom ordering them then you can look into something called a T frame security hanger. They make numerous styles of clips exactly like that for hanging large picture frames to the wall. So if you start searching for heavy duty security hangers....you should stumble upon a very similar piece of metal.
Hope that helps
