Members Pablo27 Posted October 26, 2014 Members Report Posted October 26, 2014 Beautiful work Chief, especially for a slow week, couldn't get that much done in a slow month, and not even in the same ball park. How did you get the black in tooling on the banjo strap? Did you use something besides the dye? Hope I'm not asking to many questions but the work is amazing. Paul Quote In God We Trust....
Members Halitech Posted October 26, 2014 Members Report Posted October 26, 2014 It is a one over, one under braid, but it's done with two pieces of lace not one. Pretty easy once you get the gist of it., two rows of holes (there must be an even number), Start the first lace in the top holes centering the lace then skipping every other hole until to finish at the next to the last hole, you skip one, then cross the laces underneath to go to the next set of holes, stay consistent either left over right or right over left, at the next to the last hole bring the ends accross and glue them together underneath. Then repeat this with another piece of lace starting in the 2nd hole down and finishing the same way in the last hole, this lace will create the one over one under effect. Try it on some scrap, I do this technique on belts sometimes, it looks pretty good. Hope that helps, Chief Does indeed and you could use 2 different colors to make a nice effect as well Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
Chief31794 Posted October 26, 2014 Author Report Posted October 26, 2014 Beautiful work Chief, especially for a slow week, couldn't get that much done in a slow month, and not even in the same ball park. How did you get the black in tooling on the banjo strap? Did you use something besides the dye? Hope I'm not asking to many questions but the work is amazing. Paul Pablo, Don't ever worry about asking too many questions, most people on this site don't mind questions at all and I don't either. To answer your question the black in the depressions is just the Eco Flo Antique Gel, I dampen the item since the gel is water based don't know if that helps but I've always done it, (Denatured Alcohol for spirit dyes and distilled water for water based dyes), it seems to help distribut the dye and make the color more consistent), then with the antique gels I apply them with sheeps wool, put them on pretty thick and get it very even and covered completely making sure it gets down in all the depressions well, then wipe the surface with clean cloths until I get the excess off, I also take a damp (not heavy) cloth and gently wipe the surface to remove residual pigment, then wipe again with cloth. You want to make sure that you don't remove the gel from down in the depressions, then let it dry for at least 12 hours then put two light coats of Neat Lac to seal it. Hope that helps, Chief Quote "Life's too short to carry ugly leather"
Members Pablo27 Posted October 27, 2014 Members Report Posted October 27, 2014 That's what I suspected, however I miss understood your post about the Banjo strap and plain wallet being done with British Tan (2 parts dye,, 1 part thinner) I thought you had dyed the strap instead of using antique, do you thin the antique? I love your work and appreciate all the help you give those trying to learn. Thanks again. Paul Quote In God We Trust....
Chief31794 Posted October 27, 2014 Author Report Posted October 27, 2014 That's what I suspected, however I miss understood your post about the Banjo strap and plain wallet being done with British Tan (2 parts dye,, 1 part thinner) I thought you had dyed the strap instead of using antique, do you thin the antique? I love your work and appreciate all the help you give those trying to learn. Thanks again. Paul I don't cut the Eco Flo Gel nor the Fiebings Antique Stain (I use both), this was the eco flo straight out of the bottle. Chief Quote "Life's too short to carry ugly leather"
