Members Beadweaver Posted October 27, 2014 Members Report Posted October 27, 2014 Hi, I'm relatively new to working with leather. I do beadwork and work mostly with tanned hides. I have a question.... I would like to stain an elk hide for a possibles bag (contemporary design) and would like to use some Mayan Blue pigment. I've done my research ... and all signs point to mixing the pigment with vodka for the best pigment dissolution and applying it to a dampened surface by vigorously rubbing it in. Then, let dry. Then buff (to remove excess pigment and rub in the stain) ... What would you recommend I seal it with? And will the dye rub off after it is sealed? My hide is very soft and I'd like to keep it that way. I plan to put the buff/sueded side on the interior and the skin side on the exterior. The skin side is what I'd like to stain. One site, Earth Pigments, recommends sealing with a fixative spray such as that which charcoal artists use. I'm not sure that will work for leather? The hide is very likely German Tanned since I got it from Crazy Crow. Not sure if that means it has been veg tanned....and how that will affect the pigment uptake. Thanks! Sue Mandel Quote
