biker55
Leather Hole Punch
hello all, what type of punch do you use for lacing work? thanks
I use punches from the mini punch set, you can get them from Tandy or Springfield or several other places. For 3/32" I use the 00 size and the 0 size on the corners, for 1/8" lacing I use the 0 size and the 1 size on the corners. On the corners I punch the corner hole and the one on each side of it 1 size larger to facilitate working around the corners. I hope that's what you were looking for. By the way I put the holes (center) 1/8" from the end on 3/32 and 3/16" from the edge on 1/8"
Chief
thanks Chief for responding. will give it a shot.
