First clicker dies and the strap it made!
http://i1161.photobucket.com/albums/q512/gregspitz/1D052BA7-F193-4A5F-92ED-003A4A554C5F.jpg
http://i1161.photobucket.com/albums/q512/gregspitz/872B7EF0-FB59-4A0A-A971-CDD8E008EAC1.jpg
Thanks to Tom for the pattern drawing to make the dies( see thread in patterns and templates)
  • 3 months later...
The dies just cut out the straps. The other work skiving gluing sewing and punching holes are done separate with sewing machine or hand sewing and hand tools. There are many videos on YouTube making watch straps. (Not my videos)
  • 5 months later...
is your clicker is 4 ton or 8 ton ?
holes punched with a rotary hole puncher..measured out and centered first and marked with an aw
usually the holes are 6-7mm apart from the center of the hole..
I''m guessin' that many holes punched together would make it very difficult to get teh leather off the punch without deformation / stretching.
The hole placement changes dependent on the length of strap I make. So unless you are making only 1 length of strap you have to customize the hole placement.
