bcflyguy Posted January 24, 2015 Report Posted January 24, 2015 I have dyed a piece too dark. The piece is not sealed yet.( no Resolene)How do I redye it to make it a different color thanks Neil ps I originally used Fiebing Eco flo Quote
Troy I Posted January 24, 2015 Report Posted January 24, 2015 You could try to buff it out with rubbing alcohol...I have done this with professional oil dyes, but not with Eco Flo. Try on some scrap leather first. Just a suggestion...good luck. Quote
bcflyguy Posted January 24, 2015 Author Report Posted January 24, 2015 Thanks for the idea Troy Quote
Members camano ridge Posted January 24, 2015 Members Report Posted January 24, 2015 First thing we need to carify what dye you are using. Eco Flo is Tandy's water based dye. Yes you can use a coarse cloth with alchol, you will only lighten the color you will not remove it completely. You could also try oxalic acid it will bleach leather and again will probably only lighten the color not remove it completely. You are not going to be able to go from dark brown to light tan type of change. What color did you dye it and what color do you want to change to. One thing in using dyes does not matter if it is Fiebings or Eco FLo I thin my dyes and then apply light coats until I get the look I want. Quote
Members CoreyChiev Posted January 27, 2015 Members Report Posted January 27, 2015 No to hijack the thread, but I've also got a similar problem to this one. I went a little bit too dark. I used Fiebings Light Brown alcohol based dye. Would there be something I could use to lighten it a tad? I'm not looking for a miracle eraser, but I'm curious to try something on it. Thanks, Corey Quote
Members camano ridge Posted January 27, 2015 Members Report Posted January 27, 2015 Corey, see my post above yours. Alcohol will lighten it just put some on a rag and rub. Try it on an out of sight area to see if it gives you the effect you want. Quote
Members CoreyChiev Posted January 27, 2015 Members Report Posted January 27, 2015 Would the dye reducer work, or should I go get some isopropyl alcohol? Quote
Members camano ridge Posted January 28, 2015 Members Report Posted January 28, 2015 I don't know what dye reducer you are using. Read the label if there is a fair amount of alcoholl in it may work. Try it and see. Quote
Members byggyns Posted January 29, 2015 Members Report Posted January 29, 2015 Fiebing's dye reducer is a mix of Ethanol (denatured alcohol) and Propanol (rubbing alcohol) acording to their MSDS. So, yes, dye reducer would work for what he is suggesting. It's also a good idea to keep that in mind for the future. You can mix your own dye reducer formula for less than $10 a quart. That's a lot less than the $20 that Tandy charges (at Elite club level). The effective differences between the two types of alcohol are not much when dealing with leather. So, using either the 90% rubbing alcohol or denatured alcohol by themselves is also an option. Quote
