Members calanneh Posted November 12, 2008 Members Report Posted November 12, 2008 Why does my Fiebing USMC Black not like Eco-Flo Satin Sheen???? I have used it on three problems now and each time I put the Satin Sheen on, the black starts to lift off the leather instantly!!! I have been using the same black with Eco-Flo Super Sheen with no probs, it just happens with the Satin Sheen. The first time it was on a project my son was working on and I only saw the end result, not as he was working. My Tandy guys said maybe he had way too much Sheen on the leather or he didnt let it dry long enough and it leeched the black out while the sheen was drying. So I tried it on two more projects myself and both did the same thing. The first wasnt so bad, just a few small tan spots along the edges so I touched it up and moved on. However, tonight I was dyeing some straps and as soon as the Sheen touched the black, the black leeched off in large areas.... I set it all aside until I can figure out what the hell is going on. Any ideas?? William Quote William Tandy Store #17 800-772-2629 Union City, CA
Members HarryB Posted November 13, 2008 Members Report Posted November 13, 2008 Welcome to the wonderful world of "dying leather black"! It has to be the most frustrating thing I have ever tried to do. I apply a thin coat of Neatsfoot oil to dry leather to open the pores, apply 3-4 coats of dye, let it dry troroughly and buff off the residue with a paper towel or cloth, apply a good coat of saddle soap and let that dry. Then try to apply your finish with a very light hand. Usually, I try to use the same brand dye and finish. Quote
tashabear Posted November 13, 2008 Report Posted November 13, 2008 Why does my Fiebing USMC Black not like Eco-Flo Satin Sheen???? I have used it on three problems now and each time I put the Satin Sheen on, the black starts to lift off the leather instantly!!!I have been using the same black with Eco-Flo Super Sheen with no probs, it just happens with the Satin Sheen. The first time it was on a project my son was working on and I only saw the end result, not as he was working. My Tandy guys said maybe he had way too much Sheen on the leather or he didnt let it dry long enough and it leeched the black out while the sheen was drying. So I tried it on two more projects myself and both did the same thing. The first wasnt so bad, just a few small tan spots along the edges so I touched it up and moved on. However, tonight I was dyeing some straps and as soon as the Sheen touched the black, the black leeched off in large areas.... I set it all aside until I can figure out what the hell is going on. Any ideas?? William How long are you letting the black dry? Also, I find that with the Eco-Flow, I have to layer the black over Evening Blue to get the deep, rich color I'm after. That, or say the hell with it and use spirit dyes while I can. ;-) Quote
Members calanneh Posted November 13, 2008 Author Members Report Posted November 13, 2008 My latest project that had this happen was dyed in the morning and then buffed/sheen'd that evening...well over 8 hours of drying time. I have a batch of vinegaroon brewing up.... I think I will just stick to it when I need somehting black. LOL Thanks for the help folks... any other thoughts are greatly welcome! William Quote William Tandy Store #17 800-772-2629 Union City, CA
Members Rawhide Posted November 13, 2008 Members Report Posted November 13, 2008 I just asked a similar question to Peter Main and here's his answer: Just get some Fiebings 'oil dye'...put on the gloves...pour some onto sheepsfleece....apply it as evenly as possible (no need to completely saturate the leather)...add also to the back. Allow to dry over night....buff with fleece...add a finish and all is done. Tiz best to slick edges and back after dying...a little oil will help slick the grain on the flesh side...use a glass slicker for this. Peter Quote Marlon
Members calanneh Posted November 13, 2008 Author Members Report Posted November 13, 2008 Thanks Marlon! I bought some fiebing's spray sheen yesterday while at Tandy. I used it on the problem project listed above and it came out looking fine. I will have to looke into the 'oil dye' idea too. I am not that good at getting even colors with dyes or stains, do the oils come out more consistant? William Quote William Tandy Store #17 800-772-2629 Union City, CA
tashabear Posted November 13, 2008 Report Posted November 13, 2008 Thanks Marlon!I bought some fiebing's spray sheen yesterday while at Tandy. I used it on the problem project listed above and it came out looking fine. I will have to looke into the 'oil dye' idea too. I am not that good at getting even colors with dyes or stains, do the oils come out more consistant? William How are you applying them? I had this problem too, because I was using daubers. Then I started using sheepskin scraps, and it's like night and day. Quote
Members calanneh Posted November 13, 2008 Author Members Report Posted November 13, 2008 How are you applying them? I had this problem too, because I was using daubers. Then I started using sheepskin scraps, and it's like night and day. Daubers..... hhhmmmm, another new idea to try!!! Thanks folks!!!!!! William Quote William Tandy Store #17 800-772-2629 Union City, CA
Members Rawhide Posted November 14, 2008 Members Report Posted November 14, 2008 Thanks Marlon!I bought some fiebing's spray sheen yesterday while at Tandy. I used it on the problem project listed above and it came out looking fine. I will have to looke into the 'oil dye' idea too. I am not that good at getting even colors with dyes or stains, do the oils come out more consistant? William Oil dyes penetrate more deeply and yes I believe more evenly. However, you should try them as suggested with the sheepswool scraps in a circular motion. This will give a slight burnishing effect as you're applying and effectively start to seal the fibers. Marlon Quote Marlon
Members calanneh Posted November 14, 2008 Author Members Report Posted November 14, 2008 Oil dyes penetrate more deeply and yes I believe more evenly. Marlon Good cuz I am horrible at dying.... I can never get them even...unless it's black of course!!! LOL William Quote William Tandy Store #17 800-772-2629 Union City, CA
