Members MuddyClearWaters Posted February 3, 2015 Members Report Posted February 3, 2015 So I recently purchased a singer 153K104. It's seen some serious use and probably a few less than enthusiastic mechanics. I paid a mechanic here in town to replace the timing belt, fix a broken guide part in the vibrating presser foot bar and set the needle timing. I was able to sew for about 20 minutes with 2 layers of 2 ounce chrome and 1" of foam between before shit hit the fan. The hook is grabbing the thread and then instead of passing it over the top of the bobbin and completing the loop, it is becoming wound around bobbin case and then jams between the case and the rotating hook right underneath the beveled top. The bobbin case and assembly itself is very loose and has play vertically as well is in all directions. I've got both the user and parts manual but I'm not seeing a diagram for the removal or tightening the actual bobbin itself. Any help on locating the set screws to remove the play in the bobbin assembly would be greatly appreciated. Quote Custom Leather Bicycle Saddles and Accessories www.carsonleh.com Singer 110W124 Singer 52W19
Members Constabulary Posted February 3, 2015 Members Report Posted February 3, 2015 (edited) sounds like a very worn hook or bobbin case. There is no screw for tightening. You either have to replace the bobbin basket or the entire hook. But first I´d check if the timing and the needle position is correct. If the 153 manual is not helping then the Consew 227 manual (download link) is worth to check. Edited February 3, 2015 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
