DannyBoyCustomLeather
Holster For A J Frame Sw
Hey there can I use a SW "J" frame 2" to make a holster for a SW 60-15?
I can work out the 3" barrel and extended extractor pin but are there any other differences I need to consider?
The 60-15 is a J frame with a 3" barrel. So the answer is yes as long as you take into consideration the 3" barrel and full length ejector shroud. The frames are the same.
I thought so, thanks for the reply! Customer said it dont fit and I made allowances for the extra barrel etc. oh well ill see it when he sends it back and ill find an actual SW 60 to try in it...... REFUND
Camano
I usually don't attempt a project without the exact blugun, to assure confidence in proper fit. I was having good success for a while, the problem I see is the FRONT SIGHT is also 1/4 maybe 3/8" bigger then the j frame snub nose that I used. My FFL reviews as well as myself failed to notice that difference.....shame. My first unhappy customer.
I will have to order blue guns when needed, the cost of doing business.
Dan
Yep your right, That front sight would definitely make things a little tight. Depending on your construction (pancake etc. and how tight your stitch line is you could possibly stretch it enough. However it sounds like you have already decided to not re do. You will find it happens occasionally even if you have a blue gun.
Scott
Scott
I wish I knew this from the get go, I must add to SW notes. You said I could have sizing problems even when using a blue gun, yikes , have not had any complications till now. I have substituted a SW 686 L frame for the ruger GP 100, and have done a few shims for lasers but always had good results. I stitch tight and always think minimal material and size is better.
Thanks for your advice Scott and the many blessings that this forum offers
Dan
