Hi folks, I've been browsing for a few weeks and thought I'd best pop in and introduce myself.
I got into leather working last year through wanting to learn to make watch straps. Since then I've moved onto belts, wallets etc. I've learned a great deal already and hoping to learn more by hanging round here. I've already had some great inspiration from the gallery and picked up some excellent tips on edging.
I'm a bit stuck with streaky dying at the moment but hoping to sort that out next.
Cheers.
Pete.
Edited by Petewon
Hi Pete, welcome to the forum.
How are you applying the dye? It might help to moisten the leather first. I use an airbrush when possible.
Hi Odin, yes I an dampening the leather first. I'm using feibings spirit and oil dyes and applying with a sponge. It's mainly lighter colours im having issues with. I've tried reducing the dye but still get inconsistent results.
I'm going out tomorrow to buy a compessor and airbrush which I'm hoping will solve the problem.
Hi Pete,
I have found that even the light oils from my hands can cause streaking of oil and spirit dyes by disrupting the absorption of the dye. I use Fiebing's Deglazer Cleaner first to make sure all surface oils are removed. This has helped me get a more consistent absorption of the dye.
Bill B. Nead
Hello Pete and welcome to the forum.
Greetings from Central Texas!
The Grain Side Up blog
#TheGrainSideUp
If Im dying just black or dark brown over an area I use daubers and apply it in a circular motion. I also use oxalic acid crystals mixed with water to clean the leather as described in one of the Al Stohlman books. For lighter colours I find the airbrush works best for me.
I use cheap airbrushes for spraying dye over a large area, saving my more expensive ones for more precise spraying. I got a couple of cheap ones 'free' with the compressor I paid about £90 for. Id suggest one with an air tank so that the motor isn't constantly running.
Thanks for the welcome and the tips folks.
Well I jumped the gun a little and popped out to buy the compressor today. It was a cheap AS18 type compressor and the chap assured me it would not work with a spray gun which was what I wanted to use. Something to do with the CFM not being high enough in the compressor??
So the question is, should I need to use a spray gun or can I get away with an air brush? It will be used for wallets so perhaps just covering leather maybe 5 inch. I assumed the gun would have a wider spread so would cover the full 5 or so inch with just one pass whereas the airbrush would take a few strokes to cover the leather and maybe be prone to streaks. Any ideas or reccomendations on a setup would be much appreciated. I'd like to keep it under £100 if possible.
Funny thing is I'm sure I've seen a video on YouTube of a AS18 used with a spray gun and getting great results. Who kows!
Thanks again. :)
Edit:
Could I get away with something like this? http://www.ebay.co.uk/itm/AS-186-Complete-Airbrush-Kit-Compressor-With-Tank-/200600974912
Edited by Petewon
Ok so I've just watched Ian Atkinsons video on airbrushing and it seems I won't need the gun, the airbrush should do what I'm after. I reckon I'll go with that setup from ebay.
I'd definitely use an airbrush, not a spray gun. I'd go for a syphon fed model so the dye is in a bottle that connects underneath the airbrush, less chance of spillage.
Cheers for the info. I reckon i'll purchace that setup tomorrow.
