Members simran Posted May 17, 2015 Members Report Posted May 17, 2015 (edited) Located in Eastern South Dakota This is a Singer 7-31. The 31 designation, in the day, meant that this machine was a 7 class designed to be run on an old fashionedoverhead, wide belt pulley system with a clutch on the flywheel. This has all been removed and this machine is mounted IN a tableinstead of ON a table; like most of them are. It is in a Singer tablewith a Singer low speed motor (1650? rpm) made for the older period machines. The table was for, I think, a surger as the table has a bit of a cut out you can see just in front of the bed that accommodated a wider machine than the 7 Class. The 7 Class sets on two steel brackets I had made to accommodate the weight of the machine.As you can see, in the last photo, this machine makes a nice stitch.Everything works as it should and the paint & decals on this machine look good for the year. RUNS ON 110V Price: $1550.00Call 605.676.2558 I will deliver this machine up to a point free; 50 miles or so. If you want to ship it; I will put it on a pallet and haul it to Watertown, SDto a shipping company. I think this machine & table weigh in the neighborhood of 270-300 lbs. Not sure on that but close I bet. I will work with you on getting it to where it needs to go. Edited May 17, 2015 by simran
