Members rockjack Posted May 26, 2015 Members Report Posted May 26, 2015 Brading rawhide new experience. Not sure how thick strings should be. When cutting from rounds do you cut extra wide so you can split strings or do you not bother? Quote
Members bucksnort Posted May 27, 2015 Members Report Posted May 27, 2015 I like thicker strings, so I typically make mine 1/2 as thick as the width. I cut my sogas a little over twice as wide as what I want my finished width to be & split it down to close to my finished thickness & then cut it into two strings. If you try to cut say an 1/8 string out of a round it will be so thick that its hard to keep straight & run through your splitter. Good luck, Buck Quote
