On 7/18/2015 at 11:41 PM, David Bruce said:
I'm hoping that someone can help me with my new 111w 155 machine. It's cleaned, oiled and sews great but I'm having issues with the stitch length. I'm trying to change the stitch length and wonder if I'm doing something wrong. I installed a servo motor on it and when I try to adjust the stitch length I get a lot of resistance from the hand wheel and it feels like I have to force it.
When I go to adjust the stitch length I start by pressing the left button/plunger then turn the hand wheel towards me. This causes the numbers to move but also causes the belt to move. Is this ok for the servo or do I need to remove the belt when I change the stitch length? Also, the stitch setting changes on it's own once I get sewing. I guess I need to know the correct procedure first, then determine if it's a mechanical problem. Any help is appreciated.
I know this is an old thread but thought I'd chime in about the 'resistance' you are feeling while turning the hand wheel with a servo motor.  The servo motor has pads for 'brakes' and you can release them by pushing just a little on your foot pedal (make sure your machine is off) while you turn the hand wheel.
Thanks! I discovered this while monkeying around with it after I created the post.
Singer 111w155, Consew 206RB-1, Cowboy 3200, Fortuna Bell Skiver, Landis 30, Campbell Keystone Skiver, Dixon Skiver, American 3 in 1, 2 Kwikprint Model 86's and Model 64, Clicker Press, Regad Heat Creaser, Merrow 60W, Singer 114W103 and an addiction to hand tools
