Tallbald Report post Posted August 24, 2015 I use only Fiebings alcohol based dyes on my projects (black, show brown, mahogany). After thorough drying time, I rub rub rub the project with terry cloth or paper towels until no dye rubs off any further to the cloth or paper towel. Despite this rubbing, invariably, when I apply Lexol conditioner and wipe the item down more dye comes off on the towel after dryiing and THEN, when I apply Resolene to seal the item yet more dye comes off. I worry about transfer to clothing of my customer. Am I doing something wrong? Thanks. Don Quote Share this post Link to post Share on other sites
JREESER1 Report post Posted August 25, 2015 I do everything just like you describe up to the Resolene. I use Fiebing's Carnauba Cream and buff and buff. It seems to soak in a little better. I have used the Resolene (Cut to 50% with water) on USMC Black and it took a very long time to get a clean rag. I have never had issues with bleeding or color transfer with the Carnauba Cream. Hope this helps. jr Quote Share this post Link to post Share on other sites
DavidL Report post Posted August 25, 2015 This happens a lot. I would think to switch to water based dye would be easiest. I stopped using dyes altogether and pick up pre dyed leather (the only one that dye rubbed off was thoroughbred latigo which use natural finish). I don't believe I could get it as nice by myself compared to factory dyed leather,although I seen good fiebing dyed leathers. Even if factories dye by hand I think they have better dyes and better processing. Maybe let the dye fully soak in and evaporate then rub off, let it evaporate again, apply resolene multiple times. Quote Share this post Link to post Share on other sites
Tallbald Report post Posted August 25, 2015 Thank you both for responding. Since the Resolene is I believe moisture resistant, I may not have problems I worry about after it dries thoroughly. Don. Quote Share this post Link to post Share on other sites
