Members Tac Posted December 2, 2008 Members Report Posted December 2, 2008 Rather than hi-jack another thread.... I have been reading several posters comments regarding the use of Fliebing's Lt. Brown Oil Dye and it splotching and coming out inconsistant. I have been struggling with the same problems for as long as I have been trying to make Lt. Brown gear... I recently had a customer request a Lt. Brown holster set and I tried something I have never done before with the dye process. I tried using an air brush to apply it. It turned out pretty well. Usually I use a wool dauber to apply my dye, after I have wet molded the item and let it dry. The only thing I changed this go around was using an air brush to apply the dye. Since I am not experienced in using an air brush, there was a learning curve for me, but I think I could get better at it with some experience. When I use a wool dauber in the past I found that I ended up with a holster with dark spots, streaks and it was ALWAYS darker than I wanted it to be. This newer method seemed to give me a consistant color, with no dark spots, splotches or streaking. I like the shade of the color too. I do not normally de-glaze my leather (about 90% of my work is done in black and I have never needed to de-glaze in the past). I might give that a try in the future with my lighter colors of dye. I hope the picture turns out ok. I am not very handy with a camera. Let me know what you'all think. -Tac Quote -Tac "Well, I guess we did our good deed for the day Mayor"-Wyatt Earp "Tombstone"
Randyc Posted December 3, 2008 Report Posted December 3, 2008 Tac I think your holster looks real good. Did you also make the cuff case? I've also had problems with the consistancy of both Fieblings light and medium browns. I'm thinking of trying the air brush routine and have a few questions. Do you reduce the dye or use full strength? Do you use any type of spray booth ie. a cardboard box? Since you probably don't hold the holster while spraying, how do you hang the holster while spraying? Thanks Randy Quote Randy Cooley Bulldog Custom Gun Leather www.bulldogleathercompany.com
Members Tac Posted December 3, 2008 Author Members Report Posted December 3, 2008 Thanks Randy. Yes, I made the mag pouch and cuff case as well. I sell a complete set of mag pouch, holster, cuff case and badge holder to Police Officers. It works well for plain clothes carry as well as concealed for off-duty. This customer is a Detective Sergeant and she already had a badge holder in brown, so she just wanted the holster, cuff case and mag pouch. I used the dye at full strength. I have never diluted any of my dyes before, as I have never had the need. I did not use any form of "spray booth". I just hooked the air brush to my compressor in the garage, turned the pressure WAY down and tried it out on a scrap piece of leather... it worked well enough that I tried it out on the mag pouch, then the cuff case, then the holster. As for holding the pieces. I wore laytex gloves and laid out a few pieces of news paper on my bench (with a few more covering the area to prevent my tools from becoming brown). I shot the back sides first, with the pieces laying on the news paper. Because there is so little dye used and it was warm, (mid-70's in Phx. today) they dried very fast and I was able to pick them up, turn them over and do the face sides of each piece. I let that dry, then held them in my hands as I got the edges, inside the holster and mag pouch and any area's I had missed with them laying flat. The whole process took longer to set up, than to actually do. I cleaned the air brush with some paint thinner and was done. I picked up the air brush at "hobby lobby" for $22.00. I already had a small air compressor in the garage that was set up with a regulator so I could adjust my air flow pressure. It was suprisingly simple and quick. The effect it had on the final finish and color was well worth the $22.00. -Tac Quote -Tac "Well, I guess we did our good deed for the day Mayor"-Wyatt Earp "Tombstone"
Hennessy Posted December 3, 2008 Report Posted December 3, 2008 Thanks Randy.Yes, I made the mag pouch and cuff case as well. I sell a complete set of mag pouch, holster, cuff case and badge holder to Police Officers. It works well for plain clothes carry as well as concealed for off-duty. This customer is a Detective Sergeant and she already had a badge holder in brown, so she just wanted the holster, cuff case and mag pouch. I used the dye at full strength. I have never diluted any of my dyes before, as I have never had the need. I did not use any form of "spray booth". I just hooked the air brush to my compressor in the garage, turned the pressure WAY down and tried it out on a scrap piece of leather... it worked well enough that I tried it out on the mag pouch, then the cuff case, then the holster. As for holding the pieces. I wore laytex gloves and laid out a few pieces of news paper on my bench (with a few more covering the area to prevent my tools from becoming brown). I shot the back sides first, with the pieces laying on the news paper. Because there is so little dye used and it was warm, (mid-70's in Phx. today) they dried very fast and I was able to pick them up, turn them over and do the face sides of each piece. I let that dry, then held them in my hands as I got the edges, inside the holster and mag pouch and any area's I had missed with them laying flat. The whole process took longer to set up, than to actually do. I cleaned the air brush with some paint thinner and was done. I picked up the air brush at "hobby lobby" for $22.00. I already had a small air compressor in the garage that was set up with a regulator so I could adjust my air flow pressure. It was suprisingly simple and quick. The effect it had on the final finish and color was well worth the $22.00. -Tac i've been dyeing a lot here lately a way that was recently showed to me.it works well with black,propbably with any oil base dont know about stain,clean surface,neat lac ,dry ,dye,dry,rub off surface,neat lac,dry,usually enough but repeat dye n lac if needed. try on scrap n see peter john Quote
Members WaG35 Posted December 3, 2008 Members Report Posted December 3, 2008 Those are really nice Tac. I recently tried my air brush too, and I won't be going back to daubers any time soon. Quote
Contributing Member TwinOaks Posted December 3, 2008 Contributing Member Report Posted December 3, 2008 (edited) +10 for using the airbrush! I've had one sitting in the box for about 4 months now, and last Sat. decided to try it out. I wasn't using oil dyes, but the standard spirit dyes. I found that at a given setting on the airbrush, I could get several shades of the color by limiting the number of passes over the leather. For my spray booth set up, I used 'exam gloves' and the inside of the door to my shed/shop. With the spirit dyes, the leather is dry almost as soon as you're done spraying. For the first time I was able to get a nice even coat without saturating the leather and getting darker than I wanted because I had to recoat to eliminate streaks. Oh, the item I made was a cell case for my new-ish cell phone. I cut the leather about a half inch too short to fully wrap the phone; in trying to machine stitch it on a Viking 6440 I managed to completely butcher the edges when the thread balled up; I also forgot to add the hardware (thank goodness) before I got the elastic liner glued and stitched in. So, overall I absolutely wasted about an hour of layout/construction and half a sq. ft of leather, but the finish sure looked good! I also seriously doubt that I'll be using the daubers for anything but edges anymore. Edited December 3, 2008 by TwinOaks Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Members HarryB Posted December 3, 2008 Members Report Posted December 3, 2008 Just a word of caution: I was once told that air brushing Fiebing's solvent based dyes (or anyone else's, I guess) give off benzine, a highly hazerdous substance to be breathing! I have not air brushed since then and have not checked with Fiebing's to verify this. I guess we need to check this out, huh? Quote
Contributing Member TwinOaks Posted December 3, 2008 Contributing Member Report Posted December 3, 2008 (edited) Harry, what is the source of this info? I wasn't aware that benzine was a component of the sovent used in spirit dyes. Of course, this is not to say that airbrushing anything (besides acrylics and Eco dyes) should be done without adequate ventilation. Edited December 3, 2008 by TwinOaks Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Members dbusarow Posted December 3, 2008 Members Report Posted December 3, 2008 Looks great Tac. Guess I know what my next tool purchase needs to be now. Dan Quote Dan Busarow dan@fishcreekleatherworks.com http://www.fishcreekleatherworks.com/
Members HarryB Posted December 3, 2008 Members Report Posted December 3, 2008 My source is a retired geologist/current full-time saddlemaker in Colorado. I haven't taken the time to follow up on his info but haven't airbrushed any more solvent dyes, either! We need to find out. If I remember (I suffer from bouts of CRS and if you don't know what CRS is I'll e-mail you with the answer) I'll call Fiebing's Wednesday and ask the source. Then we'll know. Quote
