That's right folks, title says it all.
I've realized that something that seems so simple in the beginning of leather working can turn very complicated, and I like that. My question to you is what is the most efficient and precise tool/method to punch holes? Check out someone like faler brands work to see what I'm talking about
http://falerbrand.tumblr.com
If you run Faler and see this you do great work, good job.
What're your thoughts on the method of using a pricking wheel->punch out all holes with an awl-> then stitch all holes?
I've used a pricking iron and have hammered out all of the holes and it's worked fine because I use thicker thread but I'm switching to .6 mm and I need the holes I punch to be smaller.
Share your TECHNIQUES!!
Thanks guys
I been thinking of using a pricking wheel with edge guide, pricking iron then awl. This way there will be no scribe line visible after you stitch.
Another piece of information I read is pricking right in the middle of a line so there is no scribe line either it just seems so difficult to get this right.
Edited by DavidL
