Members gamli Posted September 26, 2015 Members Report Posted September 26, 2015 I've seen lots of recipes for finishing leather using tallow as an ingredient. All of the postings use rendered beef fat for the tallow. Would rendered deer fat work as well. Much easier to obtain where I am. Quote
Members TexasJack Posted September 27, 2015 Members Report Posted September 27, 2015 I don't know why it would be any different, though I must admit that I've never seen enough fat on a deer to make it worthwhile to use it for something. Quote
Members gamli Posted September 27, 2015 Author Members Report Posted September 27, 2015 Good point. Lots of hunters around here. I can accumulate a decent amount from several people. Quote
Members ChuckBurrows Posted September 27, 2015 Members Report Posted September 27, 2015 Yep deer tallow is good stuff especially that from around the kidneys. I use it in a mix with bear grease or lard and beeswax for a form of dubbin. Quote Wild Rose Trading Company Two roads diverged in a wood, and I, I took the one less traveled by, And that has made all the difference.
Members gamli Posted September 27, 2015 Author Members Report Posted September 27, 2015 Cool. Thanks. Ill try some with bees wax. Quote
Members TexasJack Posted September 28, 2015 Members Report Posted September 28, 2015 Bear grease? You actually have a source for bear grease, Chuck? BTW, good to see you're still vertical and ventilating! Quote
Members ChuckBurrows Posted September 28, 2015 Members Report Posted September 28, 2015 Howdy Jack - Yep I do - got a bunch last year from a friend. There's a taxidermy outfit that sells it on line - I'll see If I can find the address if your interested or do a search for both bear oil and bear grease. I'm doing OK. Two months ago found that the last chemo I went through destroyed my bone marrow, so no transplant at this time anyway, and then they started a new treatment that has helped immensely. Platelets had been down to 17,000, and two weeks ago after just the first course they were back up to 127,000. Quote Wild Rose Trading Company Two roads diverged in a wood, and I, I took the one less traveled by, And that has made all the difference.
Members gamli Posted November 5, 2015 Author Members Report Posted November 5, 2015 Just rendered down about 2 lbs of deer fat. Got about 12 oz of tallow. Im gonna mix it with beeswax and test it out. Is there anything else i should add? Maybe 100 % neatsfoot oil or lard? Quote
Members ChuckBurrows Posted November 5, 2015 Members Report Posted November 5, 2015 gamli - I only add oil if the wax/tallow is to stiff. I want it fairly stiff, but soft and creamy enough to spread well without pre-heating although that doesn't hurt to melt and apply warm. Quote Wild Rose Trading Company Two roads diverged in a wood, and I, I took the one less traveled by, And that has made all the difference.
Members gamli Posted November 5, 2015 Author Members Report Posted November 5, 2015 Thanks for the input Chuck. I just combined 16 oz of tallow with about 3oz of beeswax. I'll try that and see how it works before I add any oil. Quote
