My order is a little different:
1) Cut out pattern
2) Light sanding of edges
3) Cut stitching groves
4) Stain leather
5) Sew areas that can't be sewn after gluing.
6) glue and clamp
7) Re-touch edges by sanding
8) Sew
9) Wet mold
10) Apply finish
11) Sell
JR
I think you have everything you need. Definitely bring the stitches in closer to the gun. Everyone has their way but I measure the thickness of the gun then split the difference cheating in a scootch, which is immeasurable and done by eyeball, on either side. If I am using the same color thread as the body then I will usually dye after wet form but if I want to do contrasting stitching I will stain before stitching. If I am going to tool then I stain before stitching but antique after wetmold. It all depends. My process for a brown holster with brown thread is usually
Cut out pattern
Dye insides
Apply glycerine and slick insides well ( I dont apply dye or glyserin to the areas that will be glued )
Glue (once I glue I put it under some books and weights and it sits over night.)
Sand edges
Stitch
wetform
Dye body
After its good and dry I do a soft secondary sand to the eddges. ... Wet molding and bending and drying can move the edge around or swell it just enough to make burnishing a mess so although I already sanded I go in now and tighten it up.
Dye edges
Burnish
Seal with sealer of choice
I dont like edge coat much. Maybe I havent found the right brand. I have taken to applying a coat or two of Super sheen just to the edges as my final step. I usually use resolene 50/50 as the body sealer so the super sheen on the edge is a nice contrast.
If you dont want to spend the money now for a belt punch you can always use a regular hole punch in the size you want, make the holes the distance apart you want and connect the two holes with a razor. Works wonderfully and its neat if not the most time efficient. You probably already have the hole punches.
Your dye looks like you are applying with a dauber and doing it linearly. Dont be afraid to use the dye and when applying if you are using a dauber make circles but dont be stingy. After years of using those damned daubers I realized I get much better result using pieces of rag and started just using pieces of old tee shirts. Put on a glove .. wet the piece of rag really well and making circles rub it in to the leather. Makes for nice effects. but again be generous.
Edited by Boriqua
