Members novaroper Posted January 19, 2016 Members Report Posted January 19, 2016 I have juki 563 I cant turn the machine buy hand unless I remove the feed dog plate but I think the shuttle suppose to be lock in under the plate if the plate is screwed down tight the machine will not role over please help Quote
Members Constabulary Posted January 20, 2016 Members Report Posted January 20, 2016 When it works w/o needle plate I would guess the feed dog is hitting or rubbing on the needle plate so you have to lower it a little bit. Right feed dog hight is when the feed dog sticks out of the needle plate approx. a tooth hight or approx 0.8 - 1mm Also make sure the little tongue of the bobbin case is inside the notch of the needle plate This just a suggestion since I don´t the machine in front of me. I also have attached a 563 manual that came form Keystone Sewing Machine Co. It maybe helpful for the future. Juki_LU-563_Instruction_Keyfooter.pdf Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
