Members BarrelPony Posted February 3, 2016 Members Report Posted February 3, 2016 Hello! I am currently working on making a bronc halter like the ones below. But I'm having a bit of trouble figuring out how to do the leather cut out windows for the gator and hair on hide parts. It's just like a sandwich, right? A bottom piece, and then a top piece with cut out windows, and then another kind of leather to fill the space? What I can't seem to figure out, is whether there are 3 pieces stacked on top of each other or not. Are the gator and hair on hide pieces cut in the exact shape we see, or is there more sandwiched between the other two pieces? Sorry if that doesn't make sense! I'm not quite sure myself. Thanks in advance! Quote
Members Halitech Posted February 4, 2016 Members Report Posted February 4, 2016 without seeing the edges, it's hard to tell for sure but I would say it looks like 3 pieces. Depending on the look you want, you can also skive down the pieces you cut out, trimmed them a bit and put them behind the inlay pieces so the inlay is the same height as the top layer. Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
Members BarrelPony Posted February 4, 2016 Author Members Report Posted February 4, 2016 Thanks Halitech! That's a good idea. Quote
