I was wondering if anyone could share their process for tooling the gullet? I can't figure out a good way to do it. Would you tool it after cementing it in and while it's still cased on the saddle tree or fit it in let it dry and then take it out flatten it just enough to tool it then fit it back it permanently?
If you want borders around the tooling, than it is best to tool it after it is installed. No need to stamp immediately, you can re wet and stamp it after the swell cover is installed and skirts are fit for border placement. If you don't need borders, than you can stamp it past the edges flat on the bench, and then install.
Keith Seidel
Seidel's Saddlery
www.seidelsaddlery.com
