Boriqua Posted February 6, 2016 Report Posted February 6, 2016 I of course have seen the Nigel video which is great but I was having some difficulty getting my siewa Awl blade to where I needed it to be and started looking around and found this gentleman and I met with great success English is his second language but its easy enough to follow along. I should preface this with I am considered very good at tool sharpening. Been sharpening knives and more on stones for years and am the guy friends bring their knives to when they have given up and blame the steel, the maker and everyone else for their dull knife. I have soft, hard and surgical black stones, course and fine diamond hones, a spyderco hone set and some other loose sharpening tools. My go to awl blade is a pointed type I bought YEARS ago at tandy. Nice solid diamond shape and this sucker can stab a fly in midflight. I wanted to experiment with a straight sided blade to see if it would help the stitching on the back side of some of my projects so I bought a Siewa number 1 and number 2. The number 1 is a small guy I use only for inlay stuff so after about an hour polish it is good to go but the Number 2 was giving me fits. It worked but it was work and if you are going to sit and sew for 3-5 hours the last thing you want is to fight your awl. The problem was that the shoulders of the diamond shape in cross section was too steep and came to close to the tip at full thickness. I kept sharpening and polishing the contours of the blade tip as it came and was dismayed to find I was making things worse not better. I just couldnt figure it out. STUPID! I was actually enhancing the very feature that was making it difficult to penetrate!! I was further exaggerating the steep angle. So I would sharpen and the very tip would pierce the leather with ease but pushing the awl through the leather was a bear and I would push so hard it would pierce sending the ferrule banging into the leather. Then I found his video and banged myself in the head. Doh. Using his rocking motion on my stones I softened the transition from the tip to the full width of the diamond shape in profile. I posted pix below of the after. The spine used to run almost all the way to the tip. Afterward you can see the kind of V shape I created by softening that transition to full thickness. It was an AHA moment. After getting that transition in place and lessening the angle I went to 1500 grit wet dry, black stone and rouge and this sucker glides through 2 pieces of 8/9 oz leather. With the shorter broader blade its easier to keep a tight right angle to the work and it has improved my stitching on the back side of my work. Hope it helps someone out. Quote
Members zuludog Posted February 10, 2016 Members Report Posted February 10, 2016 This method looks good & interesting I have a John James awl that is yet to be mounted & sharpened; when I do, I'll try this method I have watched Paul Sellers videos on sharpening woodworking tools. I notice that he uses window cleaning spray as a lubricant on diamond stones and wet & dry paper I have an assorted pack of wet & dry paper, with 5 grades covering the range P 600 to P 2000. I think I'll make up some semi - permanent blocks, like small sharpening stones, by gluing or pinning the paper to wooden blocks Quote
King's X Posted February 11, 2016 Report Posted February 11, 2016 Good video.....thanks for sharing! Quote Greetings from Central Texas! The Grain Side Up blog #TheGrainSideUp
Members shtoink Posted February 11, 2016 Members Report Posted February 11, 2016 The only thing I can possibly add to a great video is to put a drop or two of dish soap with your water to help it wet out on the sandpaper. Just drop it directly on the paper and then dribble your water on after, nothing fancy. I've heard other people using of all sorts of different stuff to wet the paper with, but dish soap and water is cheap, easily accessible, works great, and even aids in the final clean up. I will certainly be giving the rounded tip a try, thanks for the video. Quote
Members leathertoolz Posted February 17, 2016 Members Report Posted February 17, 2016 Thanks Boriqua for sharing my video! I am very glad that it helped you! : ) Quote
Boriqua Posted February 17, 2016 Author Report Posted February 17, 2016 Thanks Boriqua for sharing my video! I am very glad that it helped you! : ) Thanks for posting it! I will have to find some time to check out your others. Alex Quote
Members Oldtoolsniper Posted February 20, 2016 Members Report Posted February 20, 2016 Thanks Boriqua for sharing my video! I am very glad that it helped you! : ) I'm glad he shared it too. I watched the video you did on a hacksaw knife. Here is what I made in a few hours. I'm shocked at how well it cuts and holds an edge. It's a used 1/2" hacksaw blade, a scrap of wood from an old piano and three inches of 5/16" brass rod. All stuff laying around the shop so my cost was in the pennies. Epoxy was the adhesive. Quote
Boriqua Posted February 21, 2016 Author Report Posted February 21, 2016 I'm glad he shared it too. I watched the video you did on a hacksaw knife. Here is what I made in a few hours. I'm shocked at how well it cuts and holds an edge. It's a used 1/2" hacksaw blade, a scrap of wood from an old piano and three inches of 5/16" brass rod. All stuff laying around the shop so my cost was in the pennies. Epoxy was the adhesive. DUDE! Thank you for the inspiration. I have been struggling along with exacto knives and box cutters for years and while I strop them before and after each use they were not ideal. After seeing your handiwork I went out to the shed and pulled out my hacksaw blade that should have been replaced years ago and made my knife. Not only is it insanely sharp but it holds an edge far better than my exacto or box cutter blades and being thcker than an exacto it doesnt flex in the turns. Awesome! I have been doing leather work since the early 90's and I still learn all sorts of new stuff visiting here Quote
Members Oldtoolsniper Posted February 21, 2016 Members Report Posted February 21, 2016 (edited) DUDE! Thank you for the inspiration. I have been struggling along with exacto knives and box cutters for years and while I strop them before and after each use they were not ideal. After seeing your handiwork I went out to the shed and pulled out my hacksaw blade that should have been replaced years ago and made my knife. Not only is it insanely sharp but it holds an edge far better than my exacto or box cutter blades and being thcker than an exacto it doesnt flex in the turns. Awesome! I have been doing leather work since the early 90's and I still learn all sorts of new /quote]I got the idea from leathertoolz, I just went farther than jus a blade. What did you cover the handle part with? By the way to drill the holes for my pins I clamped the cutting end between to pieces of steel to act as a heat sink, about an inch in the heat sink. That keeps the temper in the cutting edge. I then heated the pin area red hot to remove the temper, drilled and then pinned it. Edited February 21, 2016 by Oldtoolsniper Quote
Boriqua Posted February 22, 2016 Author Report Posted February 22, 2016 I had some horn knife scales a Buddy gave me years ago in my box of junk so I used one for the hacksaw knife. I made them a little over sized top and bottom so the hacksaw blade is kind of encapsulated in the epoxy. I am hoping It will hold without pins but thank you for tip so if the epoxy fails I can pin the next one. Quote
