Mujician
Advice With Dyeing
I'd like to get a little more adventurous with my colouring. I'm attempting to make the Tandy 'magic billfold' so its only a simple make, but I'd like to have a good design on it. If I have multiple colours (eco-flo dye) next to each other will they start to run into each other even if I leave each colour to dry first? are there any recommended videos to watch to learn about colouring? Many thanks
When dying multiple colors, you just need to be sure that your brush is not too heavily loaded with dye when doing the edges. You can use a brush that's a bit more heavily loaded near the center part, where it will not be a problem if the dye spreads a bit. There's a youtube video from Tandyleatherfactory that goes into this technique, if you're inclined to look for it.
Bill
