helena
Singer 153k tension issues I think?
I got lost in tension and am running a #24 singer 135x16 TRI with 207 poly thread in Leather cow hide it worked beautifully.Then I got cheeky and set out to change the lift of my feet, well adjusted it back to factory only to adjust the tension wrong and my current problem is
I was thinking that loosening bobbin mention would make top tention able to pull thread up but it's not working.
How does one even feel tention the bobbin thread just seemed the same with the screw adjusted all the way in
One day I will learn bear with Helena
